SLAM-ER
Mar 10, 2019Aspirant
ReadyNAS Ultra-6 data degraded after firmware update
I have an old ReadyNAS Ultra-6 that I upgraded to Firmware 6.9.5. After the upgrade it shows data degraded. However the data is not degraded, all drives are healthy, I can still access the shares...
- Mar 11, 2019
Hi again
Thanks for posting the disk info. As suspected, disk sda has seen better days. From what I can see in the logs, the disk should be located in bay 1 (the first disk in the NAS). We can see that the disk has some Current Pending Sector errors.
Device: sda Controller: 0 Channel: 0 <<<=== Bay 1 Model: WDC WD60EFRX-68MYMN0 Serial: Firmware: 82.00A82 Class: SATA RPM: 5700 Sectors: 11721045168 Pool: data PoolType: RAID 5 PoolState: 3 PoolHostId: 33eac74a Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 11 <<<=== Bad sectors on the disk Uncorrectable Sector Count: 0 Temperature: 32 Start/Stop Count: 136 Power-On Hours: 35247 Power Cycle Count: 77 Load Cycle Count: 15929
Pending sectors typically indicates imminent failure of the disk. An Acronis KB, describes the issue particularly well.Current Pending Sector Count S.M.A.R.T. parameter is a critical parameter and indicates the current count of unstable sectors (waiting for remapping). The raw value of this attribute indicates the total number of sectors waiting for remapping. Later, when some of these sectors are read successfully, the value is decreased. If errors still occur when reading some sector, the hard drive will try to restore the data, transfer it to the reserved disk area (spare area) and mark this sector as remapped.
Please also consult your machines's or hard disks documentation.
RecommendationsThis is a critical parameter. Degradation of this parameter may indicate imminent drive failure. Urgent data backup and hardware replacement is recommended.
https://kb.acronis.com/content/9133
It is quite likely that these bad sectors caused the NAS to kick the disk from the one of the data raids. The fact that those sectors appear stuck in "pending" is an indication that the sectors will probably never recover. Without further examination of the logs I'd say you need to replace that disk asap. Note: you must replace with a disk of same size or larger.
Your other disks appear to be healthy, which is good!
Cheers
SLAM-ER
Mar 11, 2019Aspirant
Device: sda
Controller: 0
Channel: 0
Serial:
Firmware: 82.00A82
Class: SATA
RPM: 5700
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 32
Device: sdb
Controller: 0
Channel: 1
Serial:
Firmware: 82.00A82
Class: SATA
RPM: 5700
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Temperature: 35
Start/Stop Count: 105
Power-On Hours: 37416
Power Cycle Count: 75
Load Cycle Count: 20776
Device: sdc
Controller: 0
Channel: 2
Model: ST6000NM0115-1YZ110
Serial:
Firmware: SN04
Class: SATA
RPM: 7200
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
End-to-End Errors: 0
Command Timeouts: 0
Temperature: 37
Start/Stop Count: 16
Power-On Hours: 4434
Power Cycle Count: 6
Load Cycle Count: 5541
Device: sdd
Controller: 0
Channel: 3
Model: WDC WD20EFRX-68EUZN0
Serial:
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 3907029168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 28
Start/Stop Count: 220
Power-On Hours: 19423
Power Cycle Count: 13
Load Cycle Count: 1799
Device: sde
Controller: 0
Channel: 4
Serial:
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 3907029168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 29
Start/Stop Count: 181
Power-On Hours: 19417
Load Cycle Count: 1794
Device: sdf
Controller: 0
Channel: 5
Serial:
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 3907029168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 29
Start/Stop Count: 223
Power Cycle Count: 14
Load Cycle Count: 1869
Hopchen
Mar 11, 2019Prodigy
Hi again
Recommendations
Cheers
- SandsharkMar 12, 2019Sensei - Experienced User
Since many users (myself included) rarely re-boot their NAS except when up-dating the OS, that re-boot can ben the cause of discovery of a problem that has actually persisted for a while. Folks tend to blame the update, but that's rarely the root cause; it's just the catalyst for the requirement to reboot. You are likely in this group; so it's not "coincidence" at all; it's a convergence of circumstance.
11 pending sectors is potentially a problem, and drive replacement seems in order. Note that since this does add additional workload to the other old drives, insuring your backup is up to date before proceeding is good insurance.
- SLAM-ERMar 12, 2019Aspirant
Thanks for all the help guys, pity the web interface couldn't tell me this info, it seems the NAS has acces to all the data for it to do so... :/ Even the LCD panel was flashing all the drives as degraded, surely it should only flash the faulty drive (disk 1) so the user knows what to replace.
I have backed it up, and will replace the faulty drive when I can afford it. :D
Appreciate the assistance.
- StephenBMar 12, 2019Guru - Experienced User
It's the entire volume that is degraded, not a disk.
But I agree that Netgear needs to a better job of identifying which disk(s) have dropped out of the array in the web UI. Forcing users to delve into mdstat.log, etc isn't great.
Also, they should implement user-defined thresholds for disk health (pending sectors, etc). 11 pending sectors are well below their hard-wired thresholds, so you will just see a "green" healthy disk in the web ui. IMO the hard-wired thresholds are too high (and based on posts here, Netgear support agrees that is the case.).
- HopchenMar 12, 2019Prodigy
I completely agree with this. It falls in the same category as the incredibly confusing message: "Remove Inactive Volumes". The challenge in this case was that sda dropped from md126 but it was still active in md127. Regardless, there should be an improved way of notifying the user other than the display blinking and showing: "Degraded". I think that user notification is an area where NETGEAR has a long way to go. It is fine if you know the system and can pull stats from logs, etc. However, for the average user, the front-end notifications are sub-par.
The disk error threshold is an interesting topic. NETGEAR has set a threshold for when to sent email notifications to the user: https://kb.netgear.com/30046/ReadyNAS-OS-6-Disk-Failure-Alerting
IMO, you cannot generalise disks errors to some arbitrary count as in, "it is only critical if you hit X mount of errors". Disks errors can hit different areas of the disk (some more important than others) and ATA errors can affect different aspects in how the disk operate.
They do need to re-think how they do this.
