miogpsrocks
May 24, 2020Tutor
Recovery
Is there a software to recover data from the readynas. My system keep disappearing off my netework and usually a restart will fix the issue. However last time it happen, the restarts are no...
May 24, 2020Guru - Experienced User
Marc_V wrote:
Regarding data recovery a lot of users here might recommend ReCLAIMe, ddrescue, r-linux.
miogpsrocks: If I recall correctly, you are running OS-6 on your Pro. If that's right, you'd need to use ReclaiMe (since you need btrfs recovery).
Note that is the array is healthy, you can directly migrate your disks to a new x86 ReadyNAS.
miogpsrocks
May 25, 2020Tutor
And if anything is done wrong, it might format all my drives and 100% data loss would result right?
