aolennick
Jul 10, 2016Tutor
RN104 freezes 5 minutes after boot
Hi, I have a problem that started just over a week ago with my RN104 freezing shortly after booting up. In its frozen state, I cannot connect to shares, the web admin page is non-responsive, Read...
Jul 11, 2016Guru - Experienced User
Try deleting the logs w/o downloading them, and see if it helps.
If it doesn't help, then you probably should use paid netgear support.
aolennick
Jul 11, 2016Tutor
I have already downloaded the logs, as this was requested by Netgear Phone support. Will this negate your suggestion?
- StephenBJul 12, 2016Guru - Experienced User
The fact that you could download them makes the odds of a filling OS partition less likely. Since you have the logs, look for /dev/md0 in volume.log and see how full the OS partition is.
If support is already working this, perhaps it's best to just let them proceed.
- aolennickJul 12, 2016Tutor
I haven't got access to the logs from this computer, but I think the drives are at around 80% full.
Phone support directed me here to get access to higher-level support, as they could not identify the problem at their level. Hopefully someone will be in contact soon.
That's the volume free space, which is different from the OS free space I asked you to check. The OS runs in a small (4 GB) partition, and the system can freeze when it gets full.
However, support should have diagnosed a full OS partition, so it almost certainly is something else.
- Jan 17, 2024Retired_Member
