tripy
Oct 14, 2015Aspirant
rn104 updated to 6.4.0 and possible solution to random lock-ups
Hello everyone, I have updated my RN104 last week, and have been poised by the unit hanging up randomly since then. I have searched andread a lot of posts here, and after 5 hard reboot and re-syn...
- Dec 02, 2015
6.4.1 is released. Who is taking the risk? :)
BrianL2
Oct 17, 2015NETGEAR Employee Retired
Hi tripy,
We may have to further investigate this issue that you've been experiencing. Kindly attach the logs so we can have a thorough look at what's going on with your ReadyNAS unit. In copying large or small files, if you will do a direct connection between your ReadyNAS and PC, will it froze or complete the copy? With regard to your downgrade question, I apologize but it won't be possible to go back to 6.2.4 or 6.2.5.
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
ifixidevices
Oct 17, 2015Luminary
It's completely possible to go back to 6.2.4 but you will have to back up your data and factory reset the unit.
First you download the 6.4.0 beta 1 or 2 (can't remember which one it is)
http://www.readynas.com/download/beta/readynasos/6.4.0/ReadyNASOS-6.4.0-T112-arm.img
Then you download the 6.2.4 download for arm processors:
http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNASOS-6.2.4_arm.zip - unzip this one to get the img file.
Manually install the first 6.4.0 image, then manually install the 6.2.4 image. Then factory reset. Boom, problem fixed.
- tripyOct 17, 2015Aspirant
Thanks for the info, IfixDevices !
I'll keep that handy, if everything else fails.
