edkedk
Jun 17, 2019Tutor
RN214 file system read-only (again)
It seems I'm extremely unlucky with this device because this is not the first time a file system error appears (cf. https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/RN204-repeated-fil...
edkedk
Jun 17, 2019Tutor
Actually, the error I mentioned in the older thread I linked in the first post happened on the other RN214 device we have in the network...
The disk was replaced in the one this thread is about.
edkedk
Jun 18, 2019Tutor
I have run the smartctl commands. On two disk there are 1 and 3 reallocated sectors. On sdd there is this error log:
Error 1 [0] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 84 -- 41 00 00 00 00 00 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 08 00 78 00 00 00 00 01 b8 40 08 00:00:32.826 READ FPDMA QUEUED 60 00 08 00 70 00 00 00 00 01 b0 40 08 00:00:32.826 READ FPDMA QUEUED 60 00 08 00 68 00 00 00 00 01 a8 40 08 00:00:32.825 READ FPDMA QUEUED 60 00 08 00 60 00 00 00 00 01 a0 40 08 00:00:32.825 READ FPDMA QUEUED 60 00 08 00 58 00 00 00 00 01 98 40 08 00:00:32.825 READ FPDMA QUEUED
- StephenBJun 18, 2019Guru - Experienced User
Error 1 [0] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) Error: ICRC, ABRT at LBA = 0x00000000 = 0
It looks like that happened when the disk was initially powered up. Did you put it into the NAS right away, or did you connect it to a PC and test it first?
It's related to the communication between the NAS (or computer) and the drive, so it could simply be a poor connection when first plugged in. I don't think this error is concerning (and don't see how it would make your system read-only, since it happened before the drive was added to the array).
The other drives with the reallocated sectors might be part of the puzzle though, and probably should be tested.
