curso
Dec 20, 2024Tutor
RN314 don't boot anymore after trying to fix "no space left on device" error.
Hi, Here's the full story that led me to a ReadyNAS RN314 that no longer starts with a "flush_space+5a" message on the LCD. Actually, after seeing that I lost (I mean visible on the network) th...
Dec 21, 2024Guru - Experienced User
curso wrote:
# mount /dev/md0 /sysroot
Killed
Ok, so that is the step that failed when you did rnutil chroot.
What does btrfs check /dev/md0 say?
curso
Dec 24, 2024Tutor
Oh sorry, I though I had answerd.
Unfortunalty, still an error:
# btrfs check /dev/md0
check_mounted(): Could not open /dev/md0
Could not check mount status: No such file or directory
Weird, I don't see any /dev/md* devices. But rnutil get_disk_info sees and list well my my 4 x 3TB disks.
# ls /dev
autofs loop3 ptp0 sdd tty13 tty3 tty46 tty62
bsg loop4 ptp1 sdd1 tty14 tty30 tty47 tty63
btrfs-control loop5 pts sdd2 tty15 tty31 tty48 tty7
bus loop6 random sdd3 tty16 tty32 tty49 tty8
console loop7 rfkill sde tty17 tty33 tty5 tty9
cpu mapper rtc0 sde1 tty18 tty34 tty50 ttyS0
cpu_dma_latency mcelog sda sg0 tty19 tty35 tty51 ttyS1
disk mem sda1 sg1 tty2 tty36 tty52 ttyS2
full memory_bandwidth sda2 sg2 tty20 tty37 tty53 ttyS3
fuse mpt2ctl sda3 sg3 tty21 tty38 tty54 urandom
hwrng mpt3ctl sdb sg4 tty22 tty39 tty55 vcs
i2c-0 mptctl sdb1 snd tty23 tty4 tty56 vcs1
input net sdb2 tty tty24 tty40 tty57 vcsa
kmsg network_latency sdb3 tty0 tty25 tty41 tty58 vcsa1
loop-control network_throughput sdc tty1 tty26 tty42 tty59 vpd
loop0 null sdc1 tty10 tty27 tty43 tty6 zero
loop1 port sdc2 tty11 tty28 tty44 tty60
loop2 ptmx sdc3 tty12 tty29 tty45 tty61
rnutil> get_disk_info
Device: sda
Controller: 0
Channel: 0
Model: WDC WD30EFRX-68EUZN0
Serial: WD-WCC4N1084860
Firmware: 80.00A80W
Class: SATA
RPM: 5400
Sectors: 5860533168
Pool: data-0
PoolType: RAID 5
PoolState: 5
PoolHostId: 7c6e9e38
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 16
Start/Stop Count: 139
Power-On Hours: 89450
Power Cycle Count: 118
Load Cycle Count: 107
Device: sdb
Controller: 0
Channel: 1
Serial: WD-WCC4N1100285
Firmware: 80.00A80W
Class: SATA
RPM: 5400
Sectors: 5860533168
Pool: data-0
PoolType: RAID 5
PoolState: 5
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 17
Start/Stop Count: 147
Power-On Hours: 89449
Power Cycle Count: 117
Load Cycle Count: 117
Device: sdc
Controller: 0
Channel: 2
Serial: WD-WCC4N1079640
Firmware: 80.00A80W
Class: SATA
RPM: 5400
Sectors: 5860533168
Pool: data-0
PoolType: RAID 5
PoolState: 5
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 17
Start/Stop Count: 137
Device: sdd
Controller: 0
Channel: 3
Serial: WD-WCC4N1090618
Firmware: 80.00A80W
Class: SATA
RPM: 5400
Sectors: 5860533168
Pool: data-0
PoolType: RAID 5
PoolState: 5
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 16
Start/Stop Count: 148
Power-On Hours: 89446
rnutil>
By the way merry Christmas.
- cursoDec 24, 2024Tutor
I ran mdadm --assemble --scan and it created the /dev/md * devices then I ran the the btrff check ...
Here are the results:
# mdadm --assemble --scan mdadm: /dev/md/data-0 has been started with 4 drives. mdadm: /dev/md/1 has been started with 4 drives. mdadm: /dev/md/0 has been started with 4 drives. # ls /dev autofs input mcelog network_throughput sda2 sdd2 tty1 tty20 tty31 tty42 tty53 tty7 vpd bsg kmsg md null sda3 sdd3 tty10 tty21 tty32 tty43 tty54 tty8 zero btrfs-control loop-control md0 port sdb sde tty11 tty22 tty33 tty44 tty55 tty9 bus loop0 md1 ptmx sdb1 sde1 tty12 tty23 tty34 tty45 tty56 ttyS0 console loop1 md127 ptp0 sdb2 sg0 tty13 tty24 tty35 tty46 tty57 ttyS1 cpu loop2 mem ptp1 sdb3 sg1 tty14 tty25 tty36 tty47 tty58 ttyS2 cpu_dma_latency loop3 memory_bandwidth pts sdc sg2 tty15 tty26 tty37 tty48 tty59 ttyS3 disk loop4 mpt2ctl random sdc1 sg3 tty16 tty27 tty38 tty49 tty6 urandom full loop5 mpt3ctl rfkill sdc2 sg4 tty17 tty28 tty39 tty5 tty60 vcs fuse loop6 mptctl rtc0 sdc3 snd tty18 tty29 tty4 tty50 tty61 vcs1 hwrng loop7 net sda sdd tty tty19 tty3 tty40 tty51 tty62 vcsa i2c-0 mapper network_latency sda1 sdd1 tty0 tty2 tty30 tty41 tty52 tty63 vcsa1 # btrfs check /dev/md0 Checking filesystem on /dev/md0 UUID: 1892115e-e870-45e4-87e6-4d9b5a202889 checking extents checking free space cache checking fs roots checking csums checking root refs found 2540609536 bytes used err is 0 total csum bytes: 2292960 total tree bytes: 134774784 total fs tree bytes: 126566400 total extent tree bytes: 4456448 btree space waste bytes: 21996338 file data blocks allocated: 3943616512 referenced 2357968896 #I ran again the cat /dev/mdstat:
# cat /proc/mdstat Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md0 : active raid1 sda1[0] sdd1[3] sdc1[2] sdb1[1] 4190208 blocks super 1.2 [4/4] [UUUU] md1 : active raid6 sda2[0] sdd2[3] sdc2[2] sdb2[1] 1047424 blocks super 1.2 level 6, 64k chunk, algorithm 2 [4/4] [UUUU] md127 : active raid5 sda3[0] sdd3[3] sdc3[2] sdb3[1] 8776244352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU] bitmap: 0/22 pages [0KB], 65536KB chunk unused devices: <none> # - cursoDec 24, 2024Tutor
Unfortunalty not yet:
# mount /dev/md0 /sysroot Killed - cursoDec 24, 2024Tutor
I noticed that each time I get a Killed error message the md devices dispear and I need to reboot and call then btrfs asseble --scan command to restore them.
I called btrfschk comand to check/repair the file /dev/md0.
I ran
btrfs check --progress /dev/md0 btrfs check --init-csum-tree --progress /dev/md0 btrfs check --init-extent-tree --progress /dev/md0After I retried the mount and it worked.
# mount rootfs on / type rootfs (rw,size=2011292k,nr_inodes=502823) proc on /proc type proc (rw,noatime,nodiratime) sysfs on /sys type sysfs (rw,noatime,nodiratime) udev on /dev type devtmpfs (rw,noatime,nodiratime,size=10240k,nr_inodes=502828,mode=755) devpts on /dev/pts type devpts (rw,noatime,nodiratime,mode=600,ptmxmode=000) /dev/md0 on /sysroot type btrfs (rw,noatime,nodiratime,nospace_cache,subvolid=5,subvol=/) # btrfs fi usage /sysroot/ Overall: Device size: 4.00GiB Device allocated: 4.00GiB Device unallocated: 0.00B Device missing: 0.00B Used: 2.29GiB Free (estimated): 1.53GiB (min: 1.53GiB) Data ratio: 1.00 Metadata ratio: 1.96 Global reserve: 64.00MiB (used: 0.00B) Data,single: Size:3.57GiB, Used:2.04GiB /dev/md0 3.57GiB Metadata,single: Size:8.00MiB, Used:0.00B /dev/md0 8.00MiB Metadata,DUP: Size:204.56MiB, Used:125.88MiB /dev/md0 409.13MiB System,single: Size:4.00MiB, Used:0.00B /dev/md0 4.00MiB System,DUP: Size:8.00MiB, Used:16.00KiB /dev/md0 16.00MiB Unallocated: /dev/md0 0.00B # - StephenBDec 24, 2024Guru - Experienced User
curso wrote:
/dev/md0 on /sysroot type btrfsSo it is mounted now.
Are you seeing anything odd when you do a ls -als /sysroot ? Normally you'd see something like this:
16 drwxr-xr-x 1 root root 260 Dec 24 00:05 . 16 drwxr-xr-x 1 root root 260 Dec 24 00:05 .. 0 drwxrwxr-x 1 admin admin 226 Jun 13 2024 apps 0 drwxr-xr-x 1 root root 1338 May 22 2023 bin 0 drwxr-xr-x 1 root root 0 May 21 2012 boot 32 drwxrwxr-x+ 1 root root 570 Jun 3 2024 data 0 drwxr-xr-x 16 root root 3440 Jun 13 2024 dev 0 drwxr-xr-x 1 root root 2800 Nov 17 15:05 etc 0 drwxr-xr-x 1 root root 54 May 22 2023 frontview 0 -rw-r--r-- 1 root root 0 Nov 9 2016 ftp_ban.tbl 0 drwxr-xr-x 1 admin admin 10 Mar 12 2023 home 4 lrwxrwxrwx 1 root root 5 Nov 22 2016 homes -> /home 0 drwxr-xr-x 1 root root 462 Feb 20 2024 lib 0 drwxr-xr-x 1 root root 40 May 22 2023 lib64 0 drwxr-xr-x 1 root root 32 Jun 4 2012 media 0 drwxr-xr-x 1 root root 0 Jan 25 2016 mnt 0 drwxr-xr-x 1 root root 98 Oct 11 2022 opt 0 dr-xr-xr-x 258 root root 0 Jun 13 2024 proc 4 -rw------- 1 root root 1024 Nov 23 2016 .rnd 0 drwx------ 1 root root 92 Nov 3 2023 root 0 drwxrwxr-x 25 root admin 840 Dec 24 05:00 run 0 drwxr-xr-x 1 root root 2590 May 22 2023 sbin 0 drwxr-xr-x 1 root root 0 Jun 4 2012 srv 0 dr-xr-xr-x 12 root root 0 Aug 22 10:29 sys 0 drwxrwxrwt 1 root root 134 Dec 24 09:17 tmp 4 -rw-r--r-- 1 root root 25 Apr 30 2019 .update_fail 0 -rw-r--r-- 1 root root 0 May 22 2023 .update_success 0 drwxr-xr-x 1 root root 70 Oct 11 2022 usr 0 drwxr-xr-x 1 root root 146 May 22 2023 varThis is a problem:
Device allocated: 4.00GiB Device unallocated: 0.00BTry running btrfs balance /sysroot/ and see if you get unallocated space back.
FWIW, my own system shows this:
Device size: 4.00GiB Device allocated: 1.53GiB Device unallocated: 2.46GiB Device missing: 0.00B Used: 1021.90MiB Free (estimated): 2.71GiB (min: 1.48GiB) Data ratio: 1.00 Metadata ratio: 2.00 Global reserve: 16.00MiB (used: 0.00B) - cursoDec 24, 2024Tutor
I rebooted and miracle it seems that everything is back.
Time will tell if all back to normal but anyway thank already for all you ahelp and support.
I have to leave for Christmas Eve and will be for two days.
Thanks again, I will keep you posted.
As mentionned it seems back. I rebooted in normal mode I have control back.
But When I will come back I will reboot in 'Tech support' mode to do a balance because I guess the FS must be unmounted.
I just ran it and I got an errror
root@readynas:~# btrfs balance --full-balance // ERROR: error during balancing '//': Input/output error There may be more info in syslog - try dmesg | tail root@readynas:~# root@readynas:~# dmesg | tail [ 2098.551351] BTRFS info (device md0): relocating block group 2818244608 flags data [ 2103.283051] BTRFS info (device md0): relocating block group 2389180416 flags data [ 2108.078305] BTRFS info (device md0): relocating block group 1960116224 flags data [ 2108.388648] BTRFS info (device md0): relocating block group 1531052032 flags data [ 2112.394487] BTRFS info (device md0): relocating block group 1101987840 flags data [ 2112.700304] BTRFS info (device md0): relocating block group 672923648 flags data [ 2118.422916] BTRFS info (device md0): relocating block group 243859456 flags data [ 2124.663008] BTRFS warning (device md0): csum failed ino 278 off 243941376 csum 2628970915 expected csum 3116378598 [ 2124.678379] BTRFS warning (device md0): csum failed ino 278 off 243941376 csum 2628970915 expected csum 3116378598 [ 2126.027199] BTRFS info (device md0): 8 enospc errors during balance root@readynas:~#I guess I have still some inconstistance on the filesystem.
How I fix them to make the balancing working?
Check the usage again, looking specifically at unallocated space.. Despite the checksum, the balance did appear to work.
What does this return?: btrfs inspect-internal inode-resolve 278 //
Normally it will return the file name of the corrupted file.
- cursoDec 25, 2024Tutor
I ran it here is the result
root@readynas:/tmp# btrfs inspect-internal inode-resolve 278 // ERROR: ino paths ioctl: No such file or directory root@readynas:/tmp# ls -il / total 48 256 drwxrwxr-x 1 root root 674 Dec 24 16:27 apps 257 drwxr-xr-x 1 root root 1738 Mar 16 2024 bin 374 drwxr-xr-x 1 root root 0 May 21 2012 boot 12249745 -rwxr-xr-x 1 root root 4160 Jun 4 2013 cp_check_md5sums.sh 256 drwxr-xr-x 1 root root 586 Dec 24 16:55 data 1025 drwxr-xr-x 16 root root 3380 Dec 24 16:01 dev 422 drwxr-xr-x 1 root root 3574 Nov 23 12:22 etc 194065248 drwxr-xr-x 1 root root 54 Mar 16 2024 frontview 89278 -rw-r--r-- 1 root root 0 Jun 18 2014 ftp_ban.tbl 256 drwxr-xr-x 1 admin admin 28 Mar 17 2018 home 9699 lrwxrwxrwx 1 root root 5 Jun 18 2014 homes -> /home 1320 drwxr-xr-x 1 root root 822 Mar 16 2024 lib 12093 drwxr-xr-x 1 root root 1304 Aug 15 2017 lib32 2197 drwxr-xr-x 1 root root 40 Mar 16 2024 lib64 2199 drwxr-xr-x 1 root root 0 Mar 23 2024 media 2200 drwxr-xr-x 1 root root 26 Jan 25 2016 mnt 2201 drwxr-xr-x 1 root root 98 Oct 11 2022 opt 193170984 drwxr-xr-x 1 root root 4 Aug 26 2023 path 1 dr-xr-xr-x 328 root root 0 Dec 24 16:00 proc 2351 drwx------ 1 root root 620 Dec 24 16:56 root 1235 drwxrwxr-x 28 root admin 1080 Dec 24 16:02 run 2355 drwxr-xr-x 1 root root 2944 Mar 16 2024 sbin 2510 drwxr-xr-x 1 root root 0 Feb 28 2012 selinux 2511 drwxr-xr-x 1 root root 0 Jun 4 2012 srv 1 dr-xr-xr-x 12 root root 0 Dec 24 16:40 sys 188474452 -rw------- 1 root root 18 Feb 21 2024 syslog 2513 drwxrwxrwt 1 root root 178 Dec 25 20:07 tmp 2514 drwxr-xr-x 1 root root 112 Oct 11 2022 usr 8070 drwxr-xr-x 1 root root 188 Mar 16 2024 var 181144103 drwxr-xr-x 1 root root 42 May 7 2022 yacht root@readynas:/tmp#Then I do not no which file(s) is(are) corrupted.
But by curiosity I ran again btrfs balance // and this time it stopped with a "no space left on device" error message. I ran several times with the same error message, but when I run "", the allocated space was no more 4.0GB 8-), there is progress.
root@readynas:/tmp# btrfs fi df -H // Data, single: total=2.59GB, used=2.23GB System, DUP: total=33.55MB, used=16.38kB Metadata, DUP: total=134.22MB, used=42.73MB GlobalReserve, single: total=33.55MB, used=0.00B root@readynas:/tmp# btrfs fi usage / Overall: Device size: 4.00GiB Device allocated: 2.72GiB Device unallocated: 1.27GiB Device missing: 0.00B Used: 2.16GiB Free (estimated): 1.61GiB (min: 993.96MiB) Data ratio: 1.00 Metadata ratio: 2.00 Global reserve: 32.00MiB (used: 0.00B) Data,single: Size:2.41GiB, Used:2.08GiB /dev/md0 2.41GiB Metadata,DUP: Size:128.00MiB, Used:40.75MiB /dev/md0 256.00MiB System,DUP: Size:32.00MiB, Used:16.00KiB /dev/md0 64.00MiB Unallocated: /dev/md0 1.27GiB root@readynas:/tmp# ls -al /var/cores/core-readynasd -rw------- 1 root root 281935872 Aug 16 2018 /var/cores/core-readynasd root@readynas:/tmp# ls -alh /var/cores/core-readynasd -rw------- 1 root root 269M Aug 16 2018 /var/cores/core-readynasd root@readynas:/tmp# - StephenBDec 25, 2024Guru - Experienced User
You now have some unallocated space so no need to run balance again.
curso wrote:
I ran it
No, you didn't. The command is
btrfs inspect-internal inode-resolve 278 //The two dashes (inspect-internal and inode-resolve) matter.
You can delete this file.
OK
Thanks for your support and help.
I whish you a nice and happy end of year 2024.
