curso
Dec 20, 2024Tutor
RN314 don't boot anymore after trying to fix "no space left on device" error.
Hi, Here's the full story that led me to a ReadyNAS RN314 that no longer starts with a "flush_space+5a" message on the LCD. Actually, after seeing that I lost (I mean visible on the network) th...
curso
Dec 24, 2024Tutor
I noticed that each time I get a Killed error message the md devices dispear and I need to reboot and call then btrfs asseble --scan command to restore them.
I called btrfschk comand to check/repair the file /dev/md0.
I ran
btrfs check --progress /dev/md0
btrfs check --init-csum-tree --progress /dev/md0
btrfs check --init-extent-tree --progress /dev/md0
After I retried the mount and it worked.
# mount
rootfs on / type rootfs (rw,size=2011292k,nr_inodes=502823)
proc on /proc type proc (rw,noatime,nodiratime)
sysfs on /sys type sysfs (rw,noatime,nodiratime)
udev on /dev type devtmpfs (rw,noatime,nodiratime,size=10240k,nr_inodes=502828,mode=755)
devpts on /dev/pts type devpts (rw,noatime,nodiratime,mode=600,ptmxmode=000)
/dev/md0 on /sysroot type btrfs (rw,noatime,nodiratime,nospace_cache,subvolid=5,subvol=/)
# btrfs fi usage /sysroot/
Overall:
Device size: 4.00GiB
Device allocated: 4.00GiB
Device unallocated: 0.00B
Device missing: 0.00B
Used: 2.29GiB
Free (estimated): 1.53GiB (min: 1.53GiB)
Data ratio: 1.00
Metadata ratio: 1.96
Global reserve: 64.00MiB (used: 0.00B)
Data,single: Size:3.57GiB, Used:2.04GiB
/dev/md0 3.57GiB
Metadata,single: Size:8.00MiB, Used:0.00B
/dev/md0 8.00MiB
Metadata,DUP: Size:204.56MiB, Used:125.88MiB
/dev/md0 409.13MiB
System,single: Size:4.00MiB, Used:0.00B
/dev/md0 4.00MiB
System,DUP: Size:8.00MiB, Used:16.00KiB
/dev/md0 16.00MiB
Unallocated:
/dev/md0 0.00B
curso
Dec 24, 2024Tutor
I rebooted and miracle it seems that everything is back.
Time will tell if all back to normal but anyway thank already for all you ahelp and support.
I have to leave for Christmas Eve and will be for two days.
Thanks again, I will keep you posted.
- cursoDec 24, 2024Tutor
As mentionned it seems back. I rebooted in normal mode I have control back.
But When I will come back I will reboot in 'Tech support' mode to do a balance because I guess the FS must be unmounted.
I just ran it and I got an errror
root@readynas:~# btrfs balance --full-balance // ERROR: error during balancing '//': Input/output error There may be more info in syslog - try dmesg | tail root@readynas:~# root@readynas:~# dmesg | tail [ 2098.551351] BTRFS info (device md0): relocating block group 2818244608 flags data [ 2103.283051] BTRFS info (device md0): relocating block group 2389180416 flags data [ 2108.078305] BTRFS info (device md0): relocating block group 1960116224 flags data [ 2108.388648] BTRFS info (device md0): relocating block group 1531052032 flags data [ 2112.394487] BTRFS info (device md0): relocating block group 1101987840 flags data [ 2112.700304] BTRFS info (device md0): relocating block group 672923648 flags data [ 2118.422916] BTRFS info (device md0): relocating block group 243859456 flags data [ 2124.663008] BTRFS warning (device md0): csum failed ino 278 off 243941376 csum 2628970915 expected csum 3116378598 [ 2124.678379] BTRFS warning (device md0): csum failed ino 278 off 243941376 csum 2628970915 expected csum 3116378598 [ 2126.027199] BTRFS info (device md0): 8 enospc errors during balance root@readynas:~#I guess I have still some inconstistance on the filesystem.
How I fix them to make the balancing working?
- StephenBDec 24, 2024Guru - Experienced User
Check the usage again, looking specifically at unallocated space.. Despite the checksum, the balance did appear to work.
What does this return?: btrfs inspect-internal inode-resolve 278 //
Normally it will return the file name of the corrupted file.
- cursoDec 25, 2024Tutor
I ran it here is the result
root@readynas:/tmp# btrfs inspect-internal inode-resolve 278 // ERROR: ino paths ioctl: No such file or directory root@readynas:/tmp# ls -il / total 48 256 drwxrwxr-x 1 root root 674 Dec 24 16:27 apps 257 drwxr-xr-x 1 root root 1738 Mar 16 2024 bin 374 drwxr-xr-x 1 root root 0 May 21 2012 boot 12249745 -rwxr-xr-x 1 root root 4160 Jun 4 2013 cp_check_md5sums.sh 256 drwxr-xr-x 1 root root 586 Dec 24 16:55 data 1025 drwxr-xr-x 16 root root 3380 Dec 24 16:01 dev 422 drwxr-xr-x 1 root root 3574 Nov 23 12:22 etc 194065248 drwxr-xr-x 1 root root 54 Mar 16 2024 frontview 89278 -rw-r--r-- 1 root root 0 Jun 18 2014 ftp_ban.tbl 256 drwxr-xr-x 1 admin admin 28 Mar 17 2018 home 9699 lrwxrwxrwx 1 root root 5 Jun 18 2014 homes -> /home 1320 drwxr-xr-x 1 root root 822 Mar 16 2024 lib 12093 drwxr-xr-x 1 root root 1304 Aug 15 2017 lib32 2197 drwxr-xr-x 1 root root 40 Mar 16 2024 lib64 2199 drwxr-xr-x 1 root root 0 Mar 23 2024 media 2200 drwxr-xr-x 1 root root 26 Jan 25 2016 mnt 2201 drwxr-xr-x 1 root root 98 Oct 11 2022 opt 193170984 drwxr-xr-x 1 root root 4 Aug 26 2023 path 1 dr-xr-xr-x 328 root root 0 Dec 24 16:00 proc 2351 drwx------ 1 root root 620 Dec 24 16:56 root 1235 drwxrwxr-x 28 root admin 1080 Dec 24 16:02 run 2355 drwxr-xr-x 1 root root 2944 Mar 16 2024 sbin 2510 drwxr-xr-x 1 root root 0 Feb 28 2012 selinux 2511 drwxr-xr-x 1 root root 0 Jun 4 2012 srv 1 dr-xr-xr-x 12 root root 0 Dec 24 16:40 sys 188474452 -rw------- 1 root root 18 Feb 21 2024 syslog 2513 drwxrwxrwt 1 root root 178 Dec 25 20:07 tmp 2514 drwxr-xr-x 1 root root 112 Oct 11 2022 usr 8070 drwxr-xr-x 1 root root 188 Mar 16 2024 var 181144103 drwxr-xr-x 1 root root 42 May 7 2022 yacht root@readynas:/tmp#Then I do not no which file(s) is(are) corrupted.
But by curiosity I ran again btrfs balance // and this time it stopped with a "no space left on device" error message. I ran several times with the same error message, but when I run "", the allocated space was no more 4.0GB 8-), there is progress.
root@readynas:/tmp# btrfs fi df -H // Data, single: total=2.59GB, used=2.23GB System, DUP: total=33.55MB, used=16.38kB Metadata, DUP: total=134.22MB, used=42.73MB GlobalReserve, single: total=33.55MB, used=0.00B root@readynas:/tmp# btrfs fi usage / Overall: Device size: 4.00GiB Device allocated: 2.72GiB Device unallocated: 1.27GiB Device missing: 0.00B Used: 2.16GiB Free (estimated): 1.61GiB (min: 993.96MiB) Data ratio: 1.00 Metadata ratio: 2.00 Global reserve: 32.00MiB (used: 0.00B) Data,single: Size:2.41GiB, Used:2.08GiB /dev/md0 2.41GiB Metadata,DUP: Size:128.00MiB, Used:40.75MiB /dev/md0 256.00MiB System,DUP: Size:32.00MiB, Used:16.00KiB /dev/md0 64.00MiB Unallocated: /dev/md0 1.27GiB root@readynas:/tmp# ls -al /var/cores/core-readynasd -rw------- 1 root root 281935872 Aug 16 2018 /var/cores/core-readynasd root@readynas:/tmp# ls -alh /var/cores/core-readynasd -rw------- 1 root root 269M Aug 16 2018 /var/cores/core-readynasd root@readynas:/tmp# - StephenBDec 25, 2024Guru - Experienced User
You now have some unallocated space so no need to run balance again.
curso wrote:
I ran it
No, you didn't. The command is
btrfs inspect-internal inode-resolve 278 //The two dashes (inspect-internal and inode-resolve) matter.
You can delete this file.
OK
Thanks for your support and help.
I whish you a nice and happy end of year 2024.
