ylafont
Feb 04, 2018Aspirant
Samba Frustrations
Windows 10 1709 (Build 16299.125) ReadyNas Pro 6 (Radiators 4.2.31 ) Windows 10 upgraded to 1709 (Build 16299.125), after which I find Samba v1 has been removed and I can no longer connect ...
TeknoJnky
Feb 05, 2018Hero
TLDR; try this and reboot
Open administrator cmd prompt
dism.exe /Online /Enable-Feature /All /FeatureName:SMB1Protocol
for some reason the forum keeps putting the emoticon, see also @ https://www.reddit.com/r/sysadmin/comments/7ac3mo/how_can_i_reenable_smbv1_in_windows_10_1709/
ylafont
Feb 05, 2018Aspirant
Had already tried most of these solutions to no avail usually i get this
Feature name SMB1Protocol is unknown.
A Windows feature name was not recognized.
Use the /Get-Features option to find the name of the feature in the image and try the command again.
also tried
Enable-WindowsOptionalFeature -Online -FeatureName smb1protocol
and no go.
Pretty much not matter what i tried, i could not install it.
- StephenBFeb 05, 2018Guru - Experienced User
Do you see it listed when you look in "turn windows features on or off"?
Use the /Get-Features option to find the name of the feature in the image and try the command again.also tried
and no go.
Do you see it in powershell when you run it as administrator?
That is, Get-WindowsOptionalFeature –Online –FeatureName SMB1Protocol
- ylafontFeb 05, 2018Aspirant
yes, all commands were execuated on a elevated Powershell window. the OS woudl otehr complain stating it needs elevated privileges.
Althouugh i am not get symtoms of a full blank features list, i am trying the steps below to see it helps.
https://www.addictivetips.com/windows-tips/fix-blank-turn-windows-features-on-or-off-list/
There might be a GPO that's blocking it. So maybe also look here: https://blogs.technet.microsoft.com/staysafe/2017/05/17/disable-smb-v1-in-managed-environments-with-ad-group-policy/
