ylafont
Feb 04, 2018Aspirant
Samba Frustrations
Windows 10 1709 (Build 16299.125) ReadyNas Pro 6 (Radiators 4.2.31 ) Windows 10 upgraded to 1709 (Build 16299.125), after which I find Samba v1 has been removed and I can no longer connect ...
Feb 05, 2018Guru - Experienced User
wrote:
Had already tried most of these solutions to no avail usually i get this
Feature name SMB1Protocol is unknown.
A Windows feature name was not recognized.
Use the /Get-Features option to find the name of the feature in the image and try the command again.
also tried
Enable-WindowsOptionalFeature -Online -FeatureName smb1protocol
and no go.
Pretty much not matter what i tried, i could not install it.
Do you see it in powershell when you run it as administrator?
That is, Get-WindowsOptionalFeature –Online –FeatureName SMB1Protocol
ylafont
Feb 05, 2018Aspirant
yes, all commands were execuated on a elevated Powershell window. the OS woudl otehr complain stating it needs elevated privileges.
Althouugh i am not get symtoms of a full blank features list, i am trying the steps below to see it helps.
https://www.addictivetips.com/windows-tips/fix-blank-turn-windows-features-on-or-off-list/
- StephenBFeb 05, 2018Guru - Experienced User
There might be a GPO that's blocking it. So maybe also look here: https://blogs.technet.microsoft.com/staysafe/2017/05/17/disable-smb-v1-in-managed-environments-with-ad-group-policy/
