abruz
Feb 02, 2018Aspirant
Scrub, Defrag, Balance: Recommended order ro remedy severely neglected maintenance
ReadyNAS 312 Firmware 6.9.2 2x4TB hard drives ~3.5TB of usable space. ~2TB of data Should leave me ~1.5TB of free space. However, I am at less than 100MB of free space. I've read thro...
- Feb 02, 2018
I think I would run Balance first, Defrag 2nd ans lastly Scrub which usually takes the longest to complete.
The data can be accessed during these, but as you suspect reponse times may be affected
bedlam1
Feb 02, 2018Prodigy
- abruzFeb 02, 2018Aspirant
Thanks. I would have blindly done it in the opposite sequence so thanks for the recommendation.
- abruzFeb 07, 2018Aspirant
Quick update......balance and defrag took some time (couple hours each) but were as expected. No increase in free space when they completed but I know each was needed. The scrub took 2 days to complete but when it was done, I reclaimed nearly 1.75TB of free space on my 4TBx2 system. Now my used/free space data looks correct.
Thanks for the assist.
- bedlam1Feb 07, 2018Prodigy
Glad it helped
