chelsel
Aug 13, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-) Cliff
fearless_fool
Jan 07, 2009Aspirant
@bollar: Thanks for the link to the Google study. One clear and surprising result in their paper: a disk drive's life expectancy is significantly enhanced if you run it hot -- between 35-40C (95-104F). And since you can slow the ReadyNAS fan speeds in software, you should be able to warm up your drives. Anyone want to try? :wink:
