chopin70
Nov 12, 2020Virtuoso
Shares user and and group permissions
Hi, 4 years after this thread... https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/User-and-group-broken-permissions/td-p/1107451/page/3 I am migrating to FreeNAS and turni...
Nov 13, 2020Guru - Experienced User
Normally I recommend leaving the file permissions set to everyone access, and controlling access with network permissions alone.
When I tried that, it is working ok.
Network Access:
File Access:
Test
I was unable to copy a file into the folder - confirming that enfants only had read access.
chopin70
Nov 14, 2020Virtuoso
nteresting
However, that is really a very bad fix you suggested
As per the doc, Network Permissions will apply Samba permissions.
However, File Permissions are related to the Unix system permissions
With your fix, if your user needs shell access, he will have r/w permissions everywhere. Worst, from my tests, it has even rmdir permission to directories he's not teh owner, which is really wired
Here's the example:
member : group
teddy : read
tommy : readw
https://imgshare.io/image/groups.N0hLn9
Shares:
share name: office
https://imgshare.io/image/share.N0hG1F
Network permissions:
group read: has read access
group readw : has r/w access
https://imgshare.io/image/network.N0hQmO
File Permissions:
allow all
https://imgshare.io/image/files.N0hooQ
Give the users shell access, then SSH into the NAS
Here are the results of the simple shell commands creating / deleting folders
# login as teddy user (ro only access to office in SAMBA)
root@NAS-01:/#
su - teddy
# teddy tries to create some files and dirs: surprise, it is possible !
teddy@NAS-01:~$
cd /medias1/office
teddy@NAS-01:/medias1/office$
touch teddy.file
mkdir teddy
touch teddy/file
exit
logout
# login as tommy (r/w access on office in SAMBA)
# and create some dirs/files
root@NAS-01:/home/admin#
su - tommy
tommy@NAS-01:~$
cd /medias1/office
tommy@NAS-01:/medias1/office$
mkdir tommy
touch tommy.file
touch tommy/tommy.file
# we have now files and dirs owned by both teddy (ro) and tommy (rw)
tommy@NAS-01:/medias1/office$ ls -la
total 32
drwxrwxrwx+ 1 guest guest 80 Nov 14 14:22 .
drwxr-xr-x 1 root root 76 Nov 14 14:15 ..
drwxrwxrwx+ 1 teddy read 8 Nov 14 14:21 teddy
-rw-rw-rw-+ 1 teddy read 0 Nov 14 14:21 teddy.file
drwxrwxrwx+ 1 tommy readw 20 Nov 14 14:22 tommy
-rw-rw-rw-+ 1 tommy readw 0 Nov 14 14:22 tommy.file
exit
logout
# teddy (ro) is back and deletes tommy's files and dirs
su - teddy
teddy@NAS-01:~$
cd /medias1/office
rm tommy.file
rm -rf tommy
ls -la
total 32
drwxrwxrwx+ 1 guest guest 50 Nov 14 14:22 .
It seems that the readyNAS doesn't properly apply ACLS permissions from within the GUI, if it even applies them at all. I did not try to apply the permissions from windows and check if they translate to ACLS in the shell and properly set the Unix permissions on access from shell. However, at the end, if it even works, it means we must setup all users file access from the gui, then from windows and that group only permissions will not apply if the user is not configured
Again, this is wired as it really works out of the box in other brands I tested while here, we don't know what kind of access is really done / applied.
- SandsharkNov 14, 2020Sensei
chopin70 wrote:nteresting
I agree. That is a good way for a home network, where SMB is typically the only protocol in use, so the admin doesn't get lost in the sea of both network and file permissions, but it is not suitable for a business environment.
- chopin70Nov 14, 2020Virtuoso
I edited first post with links to images as I cannot find a way to upload images without they get corrupted
Yes, it is really not usable in this way
I gave it another trial to properly apply ACLS group permissions using windows
If I check the "read" and "readw" groups I created, in both Network and File permissions tabs, they do not propagate to windows and we cannot apply any permissions from there. Users must be checked individually
However, if I apply the ACLS permissiosn to teddy and tommy users from windows, they properly propagate to the shell session
So, it seems like the bugs are:
- GUI doesn't set any ACLS permissions and will break SMB access if Unix File permissions are not set
- The groups we enable from GUI File Permissions do not propagate to windows ACLS properly, sometimes yes, others no
- The onyl way to properly apply the ACLS is from windows and for each user
Notice that on FreeNAS ZFS system it was only fixed recently also, so maybe it is not something that easy.
But hey, it works also on Synology which uses BTRFS like Netgear. So must not be impossible to implement.
Should this flagged again as a bug ?
- StephenBNov 14, 2020Guru - Experienced User
Sandshark wrote:
chopin70 wrote:
nteresting
I do agree that using Network Access alone doesn't work if you give a user with restricted access to files the ability to log into the NAS with SSH. But in my opinion that is bad practice anyway - only admins should have SSH access to the NAS.
I don't see what the other protocols have to do with it, since you need to set up network access for all of them properly anyway. If you try to use file permissions alone, then anyone with write access to the folder can change the permissions - so they can elevate the permissions of others. One way or another you need to set the network access for all protocols properly if you want to ensure that the restricted access sticks. And in most cases (home or business) that is enough.
- chopin70Nov 15, 2020VirtuosoIt doesn't work that way.
We should be able to set group ACLS from windows once the group permissions are specified in GUI. Currently even this basic acls part is broke.
Once ACLS permissions are set at group level, they would properly apply tu users and they will manage both smb AND unix accesses.
I have a sync_agent user to sync mobile phones to nas and an rsync user to accept pull requests for backups through ssh and not the insecure modules. So it needs a shell access with ssh cert and no pass. I also have a few users needing a shell access.
I properly secured a non root ssh access for the rsync user using sudo and a locked authorized_keys command pointing to a shell script.
In anycase, the way acls are implemented is buggy. And the way you suggest leaves a hole if a user needs shell access. The NAS is not sold as "Home only", so no excuses to leave it unfinished by Netgear. Hope it gets fixed.
Any Netgear tech we can ping ?
