theluke79
Dec 02, 2016Aspirant
SSH Configuration reset on reboot
Hi lads, I have just freshly reset my RN102. There is a bug that is annoying me terribly, every time I reboot the system the SSH configuration is messed up / lost, somehow it is being reset. ...
theluke79
Dec 04, 2016Aspirant
I hoped to solve the issue editing the SSHD file in the default folder.
It worked fine after reboot.
Until the NAS completely stuck and I had to pull the power cord to restart it.
That is when I lost SSH configuration AGAIN....
HELP!
theluke79
Using the guide I mentioned in the first post, I also edited the file in : /etc/default/config/etc/ssh/sshd_config
And it worked just until I pulled the cord.
Then the parameters went belly up again and I lost SSH.
Any help is appreciated here
- SkywalkerDec 05, 2016NETGEAR Expert
# cp /lib/systemd/system/ssh.service /etc/systemd/system/
Then modify /etc/systemd/system/ssh.service to point to your customized sshd_config file (eg. /etc/sshd/sshd_config.custom). So, your ExecStart line should end up looking something like this:
ExecStart=/usr/sbin/sshd -D -f /etc/ssh/sshd_config.custom
