mrmilo
Jun 11, 2012Tutor
sshd won't start
I'm a happy user of the ReadyNAS Ultra 6. Last month I updated RAIDiator from 4.2.20.[T32] to 4.2.20. I used to have ssh enabled. 2 weeks after the update I tried to login to ssh again but no connecti...
mrmilo
Jun 11, 2012Tutor
I know that using ssh has it's risks, i did however had ssh access mapped over the internet. As soon as the problems started i removed all mappings. My password is considered strong. I did consider the possibility i was hacked (any chance of finding that out via the logs e.a. weird ip adress connection on ssh??). Thanks to the nasinfo add-on i can still see what processes are running and which connections are made. Nothing weird to see there so if i was 'hacked' it sure was useless but maybe the hacker made a mistake and disabled my sshd beyond normal repair?!? Still a lot of maybe's. I'd really like to confirme things using logfiles. I can find many log files but they contain so much info i don't know where to start looking.
Will a firmware reinstall from the boot menu destroy my shares? And more important my Timemachine vault? (I can't risk to loose the timemachine as i'm waiting on a repair of my Macbook Pro).
