ILoveYou
Sep 08, 2023Aspirant
Startup issue and access lost (shares + frontview) on RNDU2000 OS6 (Ultra 2)
Hello, I use a readynas Ultra2 RNDU2000 with OS 6.10.8 + 2 HDD 8To Raid 1. I have an issue for a few days. I can no longer access the NAS, neither via the shares (SMB) nor via Frontview. I noticed...
Sep 09, 2023Guru - Experienced User
ILoveYou wrote:
"You might want to try using RAIDar to check the status with the 8 TB disks installed:"
Nor Raidar 4.3.8 nor 6.5.0 can detect the NAS. I assume this was due to fact that IP different of the default one are assigned.
No, that's not it. RAIDar use a discovery protocol that will find the NAS even if the IP address is misconfigured.
If you have internet security software on the PC, that might have blocked discovery.
ILoveYou wrote:
note : I didn't mount any unit, just use basic command rnutil chroot / lsblk / df.
rnutil chroot will start RAID and mount the OS partition (which is /dev/md0)
ILoveYou wrote:
I run "find . -type f -size +100M" and I found 3 files with size equals to disk size in /var/backups/md/tmp/Don't know if it is normal or not; I didn't delete/overwrite htese files these files (see botom of screenshot).
Not normal - the /var/backups/md/tmp folder doesn't exist on my NAS.
ILoveYou wrote:
"That is a possibility, though it is possible something else is going on."Do you have an idea of what could have happen ?
First issues appear while I was synchronising a large batch of photo to the nas for storage (copy from a software on windows to the share mapped in the system).
Hard to say without logs. Does
rnutil create_system_log -o filename.zip
create a log zip?
One option is to do a factory reset. That of course will destroy the data. Do you have a backup?
ILoveYou wrote:
(note: I wrote this answer earlier today and seems to me I posted it. Could it be that my previous message has been deleted by an administrator without notice ?)
There's an automatic spam filter that triggered.
ILoveYou
Sep 09, 2023Aspirant
Hello StephenB !!!!
Thanks again for your help !
"If you have internet security software on the PC, that might have blocked discovery."
You are right ! I disabled the antivirus (Avast) and Firewall (Comodo) and test again with raidar.
NAS was on, and nothing was detected.
Nevertheless, I notice that strange bahaviour : I restarded the Nas and by chance Raidar was on and I saw that during the startup phase the NAS is correctly detected. Once the system is on the NAS cannot be seen anymore. See screenchot attached
"Not normal - the /var/backups/md/tmp folder doesn't exist on my NAS."
After restart this morning these directories / files have gone. No more file over 100 Mg
"Hard to say without logs."
File log is produced.
I get the following errors :
root@2PG42xxxxx:/var/log# rnutil create_system_log -o TMPlog.zip
Failure (dbus fatal exception).
Error: Connection failure: Connection refused
sysctl: reading key "net.ipv6.conf.all.stable_secret"
sysctl: reading key "net.ipv6.conf.default.stable_secret"
sysctl: reading key "net.ipv6.conf.eth0.stable_secret"
sysctl: reading key "net.ipv6.conf.eth1.stable_secret"
sysctl: reading key "net.ipv6.conf.lo.stable_secret"
Running in chroot, ignoring request.
system log TMPlog.zip created successfully
Do I send them by PM ?
"One option is to do a factory reset. That of course will destroy the data. Do you have a backup?"
Of course I have a backup of the day of the access was lost, but better if we can make this one work (first for question of system reliability assesment and second for a question of time as reinstall from zero will be very time consuming (not sure if the configuration export is up to date...)).
Thanks for again your support !
Fred
