LeapingLemming
May 05, 2019Tutor
Synchronisation offline after RN104 upgrade to 6.10 from 6.9.5
After upgrading to 6.10, Readycloud no longer synchronises ... "Synchronisation Offline".
In the NAS admin page,, ReadyCloud is switched on, shows "Internet Available" and "Services Available" som...
- May 18, 2019
Fixed. This is the second major software glitch with this device that needed significant effort on my part to fix. I don't know what someone with no tech skills would do in this cuircumstance.
Anyway, ended up buying an external drive; backing everythng up; and doing a factory reset Restoring all the files now, but it definitely does synch again. Cost $200 for an external drive I don't need and I lost of good chunk of two weekends with a couple of evenings thrown in. At the expense of time with family.
May 07, 2019Guru - Experienced User
LeapingLemming wrote:
I have never used linux (I assume ssh is a linux shell) so I might be out of my depth there. Unless you can give me pointers.
Probably not a good time to learn.
Do you have a backup of your files? (you should, since RAID isn't enough to keep them safe). Another approach (painful, but effective) is to do a factory reset, rebuild the NAS, and restore the files from the backup.
LeapingLemming
May 07, 2019Tutor
Actually may have removed php by cleaning it from the app directory using my memories of Unix that were very old and very briefly-used. But it did not fix the problem. I do have a backup of the really important stuff, I sync several directories on the NAS to cloud storage. But not everything, like shows I recorded. So I'd prefer not to rebuild.
