LeapingLemming
May 05, 2019Tutor
Synchronisation offline after RN104 upgrade to 6.10 from 6.9.5
After upgrading to 6.10, Readycloud no longer synchronises ... "Synchronisation Offline".
In the NAS admin page,, ReadyCloud is switched on, shows "Internet Available" and "Services Available" som...
- May 18, 2019
Fixed. This is the second major software glitch with this device that needed significant effort on my part to fix. I don't know what someone with no tech skills would do in this cuircumstance.
Anyway, ended up buying an external drive; backing everythng up; and doing a factory reset Restoring all the files now, but it definitely does synch again. Cost $200 for an external drive I don't need and I lost of good chunk of two weekends with a couple of evenings thrown in. At the expense of time with family.
May 14, 2019Guru - Experienced User
My service list is slightly different (no sudo):
root@RN102:~# service --status-all [ + ] apache2 [ + ] avahi-daemon [ - ] bootlogs [ - ] bootmisc.sh [ - ] checkfs.sh [ - ] checkroot-bootclean.sh [ - ] checkroot.sh [ + ] cron [ + ] dbus [ - ] forked-daapd [ - ] hostname.sh [ - ] killprocs [ + ] leafp2p [ - ] lsyncd [ + ] minissdpd [ - ] mountall-bootclean.sh [ - ] mountall.sh [ - ] mountdevsubfs.sh [ - ] mountkernfs.sh [ - ] mountnfs-bootclean.sh [ - ] mountnfs.sh [ - ] nfs-common [ - ] nfs-kernel-server [ + ] noflushd [ + ] procps [ - ] rmnologin [ - ] rpcbind [ + ] rsync [ - ] sendsigs [ - ] snmpd [ + ] ssh [ + ] udev [ - ] umountfs [ - ] umountnfs.sh [ - ] umountroot [ + ] urandom root@RN102:~#
LeapingLemming
May 18, 2019Tutor
- StephenBMay 19, 2019Guru - Experienced User
Not sure that you don't need it. If you care about your data, then you do need a backup strategy for it. RAID isn't enough to keep it safe (with any NAS).
