okulo
Sep 27, 2015Aspirant
Time Machine verification failure (again)
I know this has been discussed before but it seems like a perennial question. The problem occurred with my ReadyNAS Duo every few months and this is the second time it has happened with my RN102 ...
Sep 28, 2015Guru - Experienced User
okulo wrote:
...I can, however, say with absolute certainty, that it never happened before I started using a ReadyNAS for Time Machine backups.
I wasn't doubting you. Just saying its been a few years since anyone has posted this issue here, and I don't think any of the other posts were for OS6 systems.
It might be on Netgear's list anyway if there are support requests. You probably should report a bug at support.netgear.com (w/o opening a case if you want to avoid a charge).
okulo
Sep 28, 2015Aspirant
Thanks.
My Mac is still busy creating a new backup so I am in the claustrophobic iPad environment. I will follow up your suggestion when I have a real keyboard in front of me.
