everytime
Sep 15, 2016Guide
Upgrade 1, upgrade all, or junk it
I have a less than two-year old ReadyNAS (516) with four 4TB drives and all is well. I also have a seven-year old ReadyNAS ProBusiness Edition. I have been using the older model to back up the newer ...
Sep 16, 2016Guru - Experienced User
everytime wrote:
Not exactly sure what I'm supposed to get, but with the -h I get 47% with two directories listed and on the -i I get 2% with the same two directories.
Do you mean 2% used or 2% free?
Perhaps cut/paste the results for both commands and post them here.
The symptoms sound like a full OS partition - which can be easily fixed if you get to it in time.
What add-ons are running? Is ReadyDLNA enabled?
everytime
Sep 16, 2016Guide
I'm not familiar with what the results mean so I'm posting a screen grab.
Also I'm not able to get the browser to access the unit so I cannot answer your questions about add-ons and ReadyDLNA completely. I think ReadyDLNA might have been checked because I used to use the box to stream music in iTunes.
Is there a way I can get answers to these questions from the command line as root?
