viperhansa
Sep 28, 2015Virtuoso
Upgrade ReadyNAS Pro Business Edition (My post seems to dissappear)
Hi again guys, I know i posted this a year ago (finally got brave and pushed into try to do an upgrade). Is it the same procedure and are there some limit on how high (or recommended version) i ...
- Oct 07, 2015
I just want to say that mdgm-ntgr and the rest of Netgear staff rock!
I followed the instructions to upgrade my old 4.x.x nas to a new 6.x.x version!
Backup.. Backup.. Backup.... Check my backups... Install PREP4TOR6_0.1-x86.bin from frontview. install R4toR6_6.3.5.bin from frontview. restart.. Put all my data back and hopefully run os6.3.5
And it worked like a charm!
Thank you all for your great work!!
1 side note, is it possible to:
1: have 24 hour clock
2: a app for handling cron works?? :-)
Best regards
Hans
viperhansa
Oct 07, 2015Virtuoso
Best regards
Hans
