AJL_Electronics
Feb 05, 2015Aspirant
Upgrading from Duo V1 to an RN102
Having had more problems than you can shake a stick at, I have ordered a pair of WD 3Tb Red drives and an RN102 NAS. Am I able to just pull the drives out of my Duo and expect them to work immediately...
AJL_Electronics
Al I have is the drives in the NAS, plus another single drive with the same data. This is the one that was screaming. I don't have anything else with the capacity to take the backup, hence buying the new RN102 and drives.
The idea of the factory reset was to set the OS all back to standard as it will not allow me to change any settings. I am doing my best not to lose all that data, which is why my idea was to default it with the drives out. Once I can talk to it, then I suppose I can just setup a backup between the units onto the 3Tb drives. If I still can't talk to it, I supose I will have to find another Duo V1 to access the data?
