khaos-spawn
Oct 02, 2016Initiate
Upgrading to 6.6.0
Have folks updated the legacy NAS units to 6.6.0? I have 6.5.1 at the moment and am wondering whether it's safe to go ahead with the upgrade.
- Oct 02, 2016
Just done it on 2 ReadyNas Appliances Pro 6 and Ultra 6 both work fine after the upgrade.
I also tested ReadyDR which works fine too
AMRivlin
Oct 10, 2016Apprentice
Just the IP change threw me off, I tried rebooting 3x, finally looked at the LED on the Pro6 and it said .177 (vs my selected static .100)
I then was able to login/etc.
AMRivlin
Oct 11, 2016Apprentice
Was still having problems, just noticed I cant get static to stick in the GUI. Keeps reverting to DHCP. Annoying.
- mdgm-ntgrOct 11, 2016NETGEAR Employee Retired
Do you still this after clearing your web browser cache?
If so, can you send me your logs (see the Sending Logs link in my sig)?
- AMRivlinOct 11, 2016Apprentice
Tried from 3 Browsers
Safari Mac
Chrome Mac
Chrome PC
Logs sent. Thanks.
- SkywalkerOct 11, 2016NETGEAR Expert
AMRivlin, can you enable Secure Diagnostic Mode, and PM me the 5-digit code? Your logs show a permissions issue with the directory where the network config file lives. Side note: your logs also show what appears to be a brute-force attack on the SSH server. You may want to remove the NAS from direct internet access, or at least disable password authentication and require keys instead.
