Cliff_MI
Jul 17, 2015Guide
UPS Communication
Has anyone has recent issues with UPS communications? I have two ReadyNAS PRO 2 and they suddenly starting having UPS communication issues. One of them has the UPS master and broadcast UPS status....
JennC
Jul 22, 2015NETGEAR Employee Retired
Hello Cliff_MI,
Since your ReadyNAS Pro 2 is running an OS6 firmware. Please try disabling the Antivirus and see if same error. Then enable it again then continue to check if you get the same error.
Cliff_MI
Sep 10, 2015Guide
I will try that, funny that would cause an issue. It just started when I updated to 6.2.4
I am using a cyberpower 625VA UPS with USB connection to the NAS.
I have hooked it up to another brand NAS and getting info off from it.
I have not gotten any error messages on the new NAS controling it, but continue to get error messages.
Failure to communicate with UPS and then 5 sec later saying that it is working again.
This goes on every few hours.
I got so tired of the issue that I deleted the UPS off of the NAS.
I will re connect and see if it changes.
Cliff
- Cliff_MISep 16, 2015Guide
I tried all of that.
No I can't seem to get the UPS network feature to work at all.
Will work on the individual machine that I plug it into but now I can't connect to it with any other device.
(I just changed some hardware switching in my network and that might be the cause of that issue)
Does anyone know what port NUT looks for? I need to see if that is blocked.
Thanks
