ndverge
Nov 02, 2015Aspirant
USB Hard Stop responding after few hours
I have a ReadyNAS 102 device and have 2 x 1TB hard disks in it. It backs up the home directory of our linux server. I enabled X-Raid and formated in Ext3. When i try to backup the whole NAS devi...
Nov 09, 2015Guru - Experienced User
You shouldn't need to unmount any NAS volumes before the backup.
There are some USB issues that were addressed in the 6.4.1 beta release - you might try that, and see if it helps.
ndverge
Nov 12, 2015Aspirant
Backup: Error backup job BACKUP_ARC: destination is read-only or files/folders could not be created. Check if these files or folders meet the destination file system limitation.
This is the error of NAS drive with the USB hard disk drive.
the NAS is stucked and USB drive also stucked at the morning when I come back to office.
- ndvergeNov 13, 2015Aspirant
If i update to version 6.4.1 beta, can i downgrade if any errors occurs.
