emillika
Jul 08, 2012Aspirant
re-using old discs for pc installation
Is there something I need to do to my 4 seagate Barracuda 7200.11's in order to re-use them in my pc after retirement from a ReadyNAS NV? My bios doesn't recognize them in my Dell XPS 8300. Have tr...
mdgm-ntgr
Jul 09, 2012NETGEAR Employee Retired
Are they recognized if you put them back in the NV? If so try a factory default then power down, remove disks and see if they then work in the PC.
