emillika
Jul 08, 2012Aspirant
re-using old discs for pc installation
Is there something I need to do to my 4 seagate Barracuda 7200.11's in order to re-use them in my pc after retirement from a ReadyNAS NV? My bios doesn't recognize them in my Dell XPS 8300. Have tr...
HERBIEO
Jul 09, 2012Aspirant
The bios should recognize them no matter how they are formatted, make sure the sata ports you are connecting them to are enabled in the bios it may have a setting which you can change from auto manual or ( not installed or disabled ) if its set to not installed or disabled the bios will not try to detect anything on that port.
