callowell
Nov 12, 2015Tutor
V4.2.28 firmware update failure
Re your email update notification 11 November 2015 All attempts to 'upload and verify' (local from your download) fail. I have A ReadyNAS Duo RND2000 Current firmware 4.1.14 Please advise
DrawsACircle
Nov 12, 2015Tutor
I tried to update my ReadyNas Ultra 2 from 4.2.27 - I get an error message stating 'Update file is not valid for this architecture' - it has been valid ever since 4,?,??
Guess Netgear needs to review either the file available for download or the list of NAS products
- JennCNov 12, 2015NETGEAR Employee Retired
Hello DrawsACircle,
Welcome to the community!
What is the FW version you are trying to upgrade to and the filename (include extension name) that you are uploading?
- DrawsACircleNov 12, 2015Tutor
I'm trying to upgrade to 4.2.28 - the filename is: RAIDiator-x86-4.2.28.zip (similar to firmware version 4.2.23 and 4.2.25 filenames)
Hello DrawsACircle,
You need to unzip the folder then you will see 2 files inside. Release notes (HTML) and the firmware file. Use the firmware file, upload it to the NAS via FrontView.
- StephenBNov 12, 2015Guru - Experienced User
Did you remember to unzip?
