howarddavidp
Dec 02, 2015Tutor
Weird Fan Problem on RNDP6000 with 6.4.0
Hello, When I have my stock 120mm rear fan (or aftermarket) plugged in, it will spin fast at boot up, but it will not spin after that. I thought the fan was bad, so I purchased a Noctua repla...
- Dec 19, 2015
I fixed it, this is the post that tells you what to do:
Add the following line to the system.conf file (I added to the end of the file& beginning) in the /etc/sensors.d folder:
ignore fan3
I actualled added both ignore 2 & 3, not sure which did the trick. There is also a file called pro6-fan.conf, so I added there as well.
Here is my entire system.conf file:
root@RNDP6000:/etc/sensors.d# more system.conf
chip "coretemp-isa-0000"
label temp2 "CPU"
ignore temp3
ignore fan3chip "w83627dhg-isa-*"
label in1 "DDB18"
set in1_min 1.62
set in1_max 1.98
label in2 "AVCC"
set in2_min 3.3 * 0.90
set in2_max 3.3 * 1.10
label in3 VCC3
set in3_min 3.3 * 0.90
set in3_max 3.3 * 1.10
label in4 VCC1_25
set in4_min 1.17
set in4_max 1.32
label in5 "VCC1_5"
set in5_min 1.41
set in5_max 1.58
label in6 "VCC1_05"
set in6_min 0.98
set in6_max 1.10
set in7_min 3.3 * 0.90
set in7_max 3.3 * 1.10
set in8_min 3.0 * 0.90
set in8_max 3.3 * 1.10
label fan1 "System"
set fan1_min 600
label fan2 "CPU"
set fan2_min 150
label fan3 "System"
set fan3_min 600
ignore fan4
ignore fan5
label temp1 "System"
set temp1_max 80
ignore temp2
ignore temp3
ignore cpu0_vid
ignore intrusion0
ignore fan3I hope this helps someone else.
David
JennC
Dec 03, 2015NETGEAR Employee Retired
Hello howarddavidp,
While waiting for others who replaced their fans too, maybe you want to check ReadyNAS OS Version 6.4.1.
howarddavidp
Dec 03, 2015Tutor
Hello,
I am running 6.4.1.
5 x 3TiB Toshiba ACA300 drives
1 x 2TiB WD Red
Stock "Crown" 120mm fan, and the Noctua 120mm.
David
- powellandy1Dec 03, 2015Virtuoso
All fine here on Pro Pioneer OS6.4.1 (Noctua system fan and CPU fan)
Andy
- howarddavidpDec 05, 2015Tutor
Still has same issue. I sent my logs in for the capacity problem, which is now resolved.
So, on bootup, fan spins just fine. Once I am booted up, the fan won;t spin. I have tried 2 fans, both do not spin after bootup.
Ideas?
David
- BrianL2Dec 05, 2015NETGEAR Employee Retired
Hi howarddavidp,
Not sure what could be the problem here. Maybe something with the chassis since it's proven that with this Firmware it works (just see powellandy1 response). Let's wait to hear from other members and contributors.
Kind regards,
BrianL
NETGEAR Community Team
- walshlinkDec 15, 2015Luminary
powellandy1,
Scrub your volume and see if your CPU temp goes through the roof...
- howarddavidpDec 19, 2015Tutor
ignore fan3
label temp2 "CPU"
ignore temp3
label in1 "DDB18"
set in1_min 1.62
set in1_max 1.98
label in2 "AVCC"
label in3 VCC3
label in4 VCC1_25
set in4_min 1.17
set in4_max 1.32
label in5 "VCC1_5"
set in5_min 1.41
set in5_max 1.58
label in6 "VCC1_05"
set in6_min 0.98
set in6_max 1.10
label fan1 "System"
set fan1_min 600
label fan2 "CPU"
set fan2_min 150
label fan3 "System"
set fan3_min 600
ignore fan4
ignore fan5
set temp1_max 80
ignore temp2
ignore temp3
ignore cpu0_vid
ignore intrusion0
David
