viperhansa
Jan 12, 2022Virtuoso
What is these folders in Admin home folder?
Hi, im running a leagcy pro 6 with os 6.10.6 and have been using os 6 for a long time. (hence no need for comments on support and stuff.. ) :smileyhappy: My question is: What is this for f...
- Jan 12, 2022
It's not that you have installed something there - much more (specifically Python) and many more applications are using the U**x home folders for storing stuff, run time data, and and and ...
Another example is ssh - the home folder is used to store accepted keys for example, by user. The location of the home folder is typically referred in Linux (or more global U**x-like OS) as ~/ , the location is defined in passwd (like /etc/passwd or in a enterprise directory (AD, LDAP, ...). If you have some basic Windows or Mess-DOS insight, you might remember autoexec.bat ... each shell does also have it's specific counterpart for it's "logon" script in the every same home folder.
schumaku
Jan 12, 2022Guru - Experienced User
It's not OS 6 related, so Netgear is out of the game.
The admin folder does parental serve as the home folder for thre admin acount, this is where e.g. the Python virtual environment is stored.
Delete? Well, this will kill any or just many App making use e.g. of Python.
viperhansa
I cannot recall that i have installed anything related to home folders....
The path for my 2 different version is as follows:
/usr/lib/python37.zip /usr/lib/python3.7 /usr/lib/python3.7/lib-dynload /usr/local/lib/python3.7/dist-packages /usr/lib/python3/dist-packages /usr/lib/python2.7 /usr/lib/python2.7/plat-x86_64-linux-gnu /usr/lib/python2.7/lib-tk /usr/lib/python2.7/lib-old /usr/lib/python2.7/lib-dynload /usr/local/lib/python2.7/dist-packages /usr/lib/python2.7/dist-packages
anything else i can check?
- schumakuJan 12, 2022Guru - Experienced User
- viperhansaJan 12, 2022Virtuoso
I leave it as is, just 35mb so.....
Thanks for your reply!
