simath
Oct 07, 2011Aspirant
Write STALLS on first try
I'm running Windows 7 64-bit SP1 with a ReadyNAS Pro 6x1TB (Seagate Enterprise drives with RAIDiator-x86 4.2.19). These are coupled directly via a Netgear GS105 switch. I've been having the follow...
simath
Oct 09, 2011Aspirant
MUCHO THANKS!!! I knew I wasn't crazy and that somebody else must have had this problem.
Yes, I'm using DHCP throughout, and my switch is indeed "dumb" (unmanaged). Based on your reply I tried something: I renewed ALL DHCP addresses (using IPCONFIG), and I turned JUMBO frames OFF. Indeed the problem went away (for now).
I think I may well buy a fully managed switch with it's OWN DHCP server (I guess that's then a "router" no longer a simple switch). Thanks for the reply - it helped a LOT!
