Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
tigerten
Jul 23, 2023Luminary
I see people is having problem installing the zerotier app. It is actually very simple. Here is how I did mine.
1. Follow Sandshark link to fix your "etc/apt/source.list)
How I got apt update and install to work
2. Download the zerotier deb, in my case it was version 1.8.7
https://download.zerotier.com/RELEASES/1.8.7/dist/debian/jessie/zerotier-one_1.8.7_amd64.deb
This is the most recent version I could install. Nothing after this
3. Install this within the Web Interface through app uploading.
4. login to SSH and type in these:
- zerotier-cli status-->output: 200 info <device address> ONLINE <zerotier version>
- zerotier-cli join xxxxxxxxxx <Your networkID> -->output: Join OK.
- (authorize device in zerotier central)
- zerotier-cli listnetworks--> outputs 200 listnetworks <nwid> <name> <mac> <status> <type> <dev> <ZT assigned ip>
dhl
tigerten wrote:I see people is having problem installing the zerotier app. It is actually very simple. Here is how I did mine.
tigerten - Is it possible to use the ZeroTier app GUI with this install method?
- tigertenJul 23, 2023Luminary
No.
Zerotier GUI does not really do much.
the setup is one time thing. once up, it is care-free. As you can see, it is just one line: join the network.
