anynamewilldo85
Apr 24, 2013Aspirant
Read Speed 3 x Slower than Write!!?
Hi I have recently purchased a ready Nas duo v2 ( 2 x 3tb Seagate barracuda drives - flexraid 0) Im seeing horrific read performance of around 1.5 MB/s where as write speed is around 4.5 MB/s ...
Apr 24, 2013Guru - Experienced User
Ok. Since you are getting 7 MB/s in both directions over wired, then slow WiFi read speed must be related to your wifi link.
It might be helpful to check the mtu size on the wireless link.
try running the windows cmd shell (type cmd in the start bar) and enter
ping -f -l 1472 NASIPADDRESS
If that fails, try reducing 1472 down to the largest value that works, and let us know what it is.
