anynamewilldo85
Apr 24, 2013Aspirant
Read Speed 3 x Slower than Write!!?
Hi I have recently purchased a ready Nas duo v2 ( 2 x 3tb Seagate barracuda drives - flexraid 0) Im seeing horrific read performance of around 1.5 MB/s where as write speed is around 4.5 MB/s ...
Apr 25, 2013Guru - Experienced User
dsm1212 wrote: Look for network errors on your laptop. Should be able to add them to task manager I believe, or use the windows perf monitor thing. Also if it's a managed switch you could look there. Could check the nas stats too to see if there are retransmits. That's in frontview.
-I don't believe you can see network errors from the task manager or the resource manager. You can see them by opening up a cmd window and typing "netstat -e". Errors and discards are shown
-He doesn't have a managed switch. Though the router might have some useful stats.
-anynamewilldo85 - are you sure you have a v2? The labels can be misleading, so check here: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/ I'm not sure where you see network stats on the v2 (or which ones it shows). I have the v1, pro, and RN102... but no v2.
