anynamewilldo85
Apr 24, 2013Aspirant
Read Speed 3 x Slower than Write!!?
Hi I have recently purchased a ready Nas duo v2 ( 2 x 3tb Seagate barracuda drives - flexraid 0) Im seeing horrific read performance of around 1.5 MB/s where as write speed is around 4.5 MB/s ...
ihartley
Apr 26, 2013Tutor
bwm is available via apt for checking bandwidth. But in all reality, the weak link is the 100Mb ethernet.
If you're using Windows you could use some TCP tweaks to make the window bigger, that might help.
I would speedtest from wlan, from fixed lan and connected directly to router. Then maybe you can see the bottleneck. Also depends whether the 100Mb is full duplex or not.
