anynamewilldo85
Apr 24, 2013Aspirant
Read Speed 3 x Slower than Write!!?
Hi I have recently purchased a ready Nas duo v2 ( 2 x 3tb Seagate barracuda drives - flexraid 0) Im seeing horrific read performance of around 1.5 MB/s where as write speed is around 4.5 MB/s ...
May 01, 2013Guru - Experienced User
Well, it could be an incompatibility in the router WiFi also. What you know is that it is the WiFi link, there is no easy way to tell which end is really at fault. If you can find a usb WiFi adapter for the laptop, that might be worth a try.
But you'd get better overall performance if you had a gigabit router, so it is worth asking Sky if you can get another one (free) first.
