NumberFour
Aug 23, 2016Tutor
Reading single disk volume (JBOD) on a computer
Hi everybody, I searched over network but didn't find a clear answer to my question. I would like to configure my NAS with a first RAID volume (let's say volume A) with 3 disks, to prevent from ...
- Oct 22, 2016
It looks like your enclosure can't handle disks > 2 TB.
You might need to get a USB 3 enclosure or SATA->USB adapter.
Aug 23, 2016Guru - Experienced User
The volume would be btrfs, not ext4.
There is a related thread here: https://community.netgear.com/t5/ReadyNAS-in-Business/OS6-Data-Recovery-How-to-Mount-BTRFS-Volumes/m-p/895578/highlight/true#M2186
Though that thread is quite old, and you probably don't need to assemble the volume with jbod.
It's clear that this can be done, but if it is an essential part of your data recovery plan you should check your ability to read the volume (as the poster on the old thread did).
- NumberFourOct 22, 2016Tutor
Hi again,
Thanks for the answer.
I tried, but I don't manage to mount the volume...
As I am using a laptop, I don't have sata directly accessible, that's why I'm using an external hard drive box, which is correctly detected as USB to SATA bridge
When I connect it, this is what appears (fdisk -l) :
Disque /dev/sdb : 746,5 GiB, 801569726464 octets, 1565565872 secteurs
Unités : sectors of 1 * 512 = 512 octets
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Périphérique Amorçage Start Fin Secteurs Size Id Type
/dev/sdb1 1 4294967295 4294967295 2T ee GPTIt's a 3TB HDD, so I'm surprised not seeing anywhere the size, maybe due to JBOD format ?
And then, here are the results of the different commands I tried :
sudo mount -t btrfs -o ro /dev/sdb1 /mnt
>mount: special device /dev/sdb1 does not exist
sudo mount -t btrfs -o ro /dev/sdb /mnt
>mount: wrong fs type, bad option, bad superblock on /dev/sdb,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.sudo mdadm --examine /dev/sdb --scan
sudo mdadm --examine /dev/sdb1 --scan(There is no output for boty of those commands)
sudo btrfs device scan /dev/sdb
>Scanning for Btrfs filesystems in '/dev/sdb'
>ERROR: device scan failed '/dev/sdb' - Invalid argument
sudo btrfs device scan /dev/sdb1
>ERROR: not a block device: /dev/sdb1I'm not a linux expert (far from that) and I don't find enough information of how to do it on Internet.
Maybe someone has an idea of what has to be done, or of what I'm doing wrong ?
Thanks in advance for all help !
- StephenBOct 22, 2016Guru - Experienced User
