MC1967
Jul 16, 2021Aspirant
ReadNAS 400v2 repair manual
Does anyone know where to get a repair manual for the ReadyNAS 4200v2? I have the user manual and the OS 6 guide, but I need the parts/repair manual. Thanks!
- Jul 16, 2021
There isn't one. Just the software and hardware manuals (and the hardware manual doesn't include anything about repair). https://www.downloads.netgear.com/files/GDC/RNDU2000/RackMount_HW_2June11.pdf
Jul 16, 2021Guru - Experienced User
- MC1967Jul 16, 2021Aspirant
I'm interested in a used 4200, but need to know how the drives are added - across the front in rows, or down the columns.
Would it be possible for someone to post a photo of how the cables for the drives are attached to the backplane?
- SandsharkJul 17, 2021Sensei
You can add drives to any ReadyNAS in any order. Across, up-down, or skipping drives for cooling enhancement. Note that the rack mount units usually come with "air dams" for use in slots without drives, and a used unit probably won''t include them
The 4200V2 is a modified SuperMicro system with a slightly modified X8SI6 motherboard and a BPN-SAS-826TQ backplane. Documentation from SuperMicro is applicable except for the IPMI interface, which has been removed. CAUTION: Don't upgrade the BIOS with just anything you download from SuperMicro, as it may not work with the ReadyNAS OS. The OS does verify it's operating on legit hardware.
There is a huge difference between a 4200 and 4200V2. Besides a slower processor, the 4200(V1) only supports 2TB drives in 8 of the 12 bays. I suggest you avoid it unless it's seriously cheap (which isn't usually the case because of shipping). Same goes for the 3200, which has the same motherboard as the 4200(V1) with an even slower CPU and less RAM. All of them use power supplies, fans, caddies, etc. for SuperMicro 2U chassis, which are readily available on eBay. The SuperMicro "dummy drives" for unused bays can also sometimes be found at a reasonable price. I've even used them in an RN4220, which is not a SuperMicro derivative (It's Chenbro, but much more customized).
The 4200(V1) and 3200 are also OEM SuperMicro units, but I forget which motherboard they use.
The 4200V2 is, IMHO, an excellent NAS when converted to run OS6. I run a converted RD5200 (same motherboard, some other differences) as my primary and 4200V2 as backup. They are, of course, noisy beasts like any other rack mount, so you need an appropriate place for them.
- MC1967Aug 02, 2021Aspirant
Thanks for the info. I have a server cabinet in my cellar, which serves two purposes - helps keep the equipment cooler and the fan noise is far away from where I sleep. The HP Proliant server I use for work is a noisy beast, also.
