Retired_Member
Mar 22, 2013Readnas DLNA streaming Setup for Android help required
I would like to set up Streaming Music and Video files that I have as Shares on my Readynas Duo v2. This works fine on my Samsung TV via Allshare and also I can see and access the Files from my wirele...
Retired_Member
Mar 26, 2013Thanks lemvigh I forgot to ask what you use as the Third party server software installed on your NAS, I did try Plex installed as an Add-on but it took ages to scan files.
Cheers
Cheers
