jiong
Dec 18, 2016Follower
ReadNAS Duo v2 corrupt root
Netgear RaidDar report NAS Server is corrupt root. So, i follow the instruction to do OS reinstall, but still shows corrupt root, i did OS reinstall for 2 times, but still same error. ...
bedlam1
Dec 18, 2016Prodigy
Your OS install changed the admin password to the default..... try the password's netgear1 or infrant1 or password, it has also changed your network settings to DHCP if that is of concern
I do not think a re-install will solve your problem though, a Factory Default will, but you will lose ALL YOUR DATA and settings
