jiong
Dec 18, 2016Follower
ReadNAS Duo v2 corrupt root
Netgear RaidDar report NAS Server is corrupt root. So, i follow the instruction to do OS reinstall, but still shows corrupt root, i did OS reinstall for 2 times, but still same error. ...
Dec 18, 2016Guru - Experienced User
Many v1 owners mistakenly believe they have a v2. A v2 runs 5.3.x firmware, a v1 runs 4.1.x. Other differences are here: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
The Os reinstall instructions for the v2 are pages 16-17 here: http://www.downloads.netgear.com/files/GDC/RND2110/ReadyNAS_Duov2_NV+v2_HW_en_23-Mar-12.pdf Note that at the end of step 4 you do need to release the reset button before you start step 5.
