Polyprop76
Dec 09, 2022Tutor
ReadNAS Duo v2 corrupt root
Hello I'm hoping someone can help me out I have A ReadNAS Duo v2 not used it for awhile so I come to use it thought I'd factory reset so it would format the HD did it via the IP address came to look ...
SamirD
Dec 09, 2022Prodigy
Is there any data you're worried about? Otherwise, don't stress. Taking the drives out and testing them in a PC may have written something to the drives that the nas doesn't understand. So, no biggie, take the drives out and wipe them in the pc and put them back in the nas and start over.
- Polyprop76Dec 09, 2022TutorThanks for the reply. I've done that re formated the 2 drives no errors put back in nas still nothing. Tried with just 1 drive in nas nothing.
- SamirDDec 10, 2022Prodigy
You can't format them--you have to completely wipe them. Use something like the parted magic live cd and wipe all the partitions and even the boot sector if possible. Then put them back in and the nas should be able to use them again.
- StephenBDec 10, 2022Guru - Experienced User
No need for special tools. You can just use the Windows disk manager to remove the partitions (clicking on each, and choosing "delete" volume). Then the NAS will see the disks as blank.
Alternatively, use the NAS boot menu to do a factory default.
Also, make sure you have a Duo v2- the original Duo is limited to 2 TB drives.
The Duo v1
- runs 4.1.x fimware
- says ReadyNAS Duo on the front panel.
The Duo v2
- runs 5.x firmware
- says ReadyNAS Duo v2 on the front panel.
Ignore other labeling, as the original Duos will often have some labeling that will lead to mis-identification.
