Polyprop76
Dec 09, 2022Tutor
ReadNAS Duo v2 corrupt root
Hello I'm hoping someone can help me out I have A ReadNAS Duo v2 not used it for awhile so I come to use it thought I'd factory reset so it would format the HD did it via the IP address came to look ...
Polyprop76
Dec 10, 2022Tutor
So wiped the drive pic attached. Put back in the nas turned it on nothing happened you can hear the nas loading up light flashing then drive light comes on, the HD isn't booting at all.
Dec 10, 2022Guru - Experienced User
What status is RAIDar giving you (with the wiped disk installed)?
- Polyprop76Dec 10, 2022TutorFirst thanks for everyone's help and replys.
Do when the drives are in says corrupt root drives out says no disk- SandsharkDec 10, 2022Sensei
And you removed all partitions from both drives? I've never seen that, but maybe you do need to use the "write zeros" option in the drive manufacturer's diagnostic tool.
- SamirDDec 10, 2022Prodigy
This is why I will usually wipe not only partitions but the boot sector as then the drive is completely 'empty' as the nas expects them to be. Hopefully that will work and it will see them again.
- StephenBDec 11, 2022Guru - Experienced User
Polyprop76 wrote:
when the drives are in says corrupt root drives out says no diskTry doing the factory default procedure described on pages 16-17 of the manual:
- Polyprop76Dec 11, 2022TutorI've tried the section 16-17 last week no joy the only option that works is tech mode I get a telnet number. Tried formatting the drives as stated above still no joy. I'm at a loss I've followed all the options I searched on the Internet before posting here.
