igelzuechter
Aug 06, 2017Aspirant
ready nas 102: Volume data is degraded
Hi folks, I was using my RN102 (OS 6.7.5) with one 3 TB disk in X-Raid mode for many years. Now I want to migrate it to Flex-Raid. So I changed the volume from X-Raid to Flex Raid, by cliking th...
- Aug 11, 2017
igelzuechter wrote:
Is there any way to migrate from two HD in X-raid mode to Flex Raid in JBOD to increase the capacity? Ideally without a backup and restore of my data?
You have to switch to flexraid, destroy the xraid volume, then create two new ones (one for each disk). I recommend naming one of them data.
There's no way to avoid data loss. Also, uninstall your apps first, as they are stored on the data volume.
Marty_M
Aug 07, 2017NETGEAR Employee Retired
Hello igelzuechter,
Upon changing from XRaid to FlexRaid were you ask to select the raid level? Degraded volume means it is up/accessible but it is not redundant. Please refer to the information from this link.
Welcome to the community!
Marty_M
NETGEAR Community Team
