Triteleaf
Jan 24, 2016Aspirant
Ready NAS 104 Locks Up (6.4.1)
Hello all! At some point that I haven't nailed down, my ReadyNas104 (6.4.1) hangs completely. All front lights get stuck solid, the screen continues displaying whatever was on it at the time of t...
- Jan 24, 2016
Thanks for the logs. Please try ReadyNASOS 6.4.2 (RC1)
There is a known RAID-5 issue you may be running into.
Looking at your logs also it looks like you still have anti-virus enabled.
Can you see if the system still locks up if anti-virus is disabled and you update to 6.4.2-RC1?Welcome to the Community!
mdgm-ntgr
Jan 24, 2016NETGEAR Employee Retired
Triteleaf
Thanks for the prompt response. I'll update straight away, and I'll fill you in on the results.
