KennyRobb
May 21, 2020Aspirant
Ready NAS 104 Slow Performance
Hi there, lets start out with the setup. I have a home network 200MB connection to outside world (via Virgin Media) I have a cable coming out the back of the VM router to my office where is connenct...
KennyRobb
May 31, 2020Aspirant
OK Factory Reset Performed and 2 day resync of drive done.
NAS in virgin state with nothing on it.
Disabled IPv6 checked all settings, switched off services not required.
Ran NASTest 400mb loop x5
Running a 400MB file write on W: 5 times... Iteration 1: 48.23 MB/sec Iteration 2: 43.38 MB/sec Iteration 3: 46.00 MB/sec Iteration 4: 42.54 MB/sec Iteration 5: 41.91 MB/sec ----------------------------- Average (W): 44.41 MB/sec ----------------------------- Running a 400MB file read on W: 5 times... Iteration 1: 48.74 MB/sec Iteration 2: 48.52 MB/sec Iteration 3: 51.52 MB/sec Iteration 4: 49.42 MB/sec Iteration 5: 51.54 MB/sec ----------------------------- Average (R): 49.95 MB/sec -----------------------------
so bottom line doing the reset has doubled the netwoek speed in this case, however it is not near what StephenB was getting on his NAS.
Where to now or do I just take the speed double and move on.
Kenny
May 31, 2020Guru - Experienced User
I'd probably take it and move on for now.
If you need the additional speed boost, you probably should consider upgrading the NAS to a faster model and then re-purpose the RN104 as a backup NAS.
