ROYW1000
Aug 07, 2016Aspirant
Ready Nas 104 Wont connect to Cloud
Hi I have had intermittent issues connecting the NAS to the ready cloud. I have deleted the NAS and tried to add it again but as soon as I toggle the Ready Cloud Button I get the 2 green ticks an...
mdgm-ntgr
Aug 08, 2016NETGEAR Employee Retired
Your NAS now shows the correct serial number and MAC addresses. Please try joining it to ReadyCLOUD again.
- ROYW1000Aug 09, 2016Aspirant
Hi
This is now working fine thank you.
Is it likely to loose the MAC and Serial Number again if I upgrade the firmware or is this now fixed for all future updates.
Thanks
Roy
- mdgm-ntgrAug 09, 2016NETGEAR Employee Retired
It would be unlikely that this would happen again on your system.
