Ianbpro3
Mar 05, 2022Aspirant
Ready NAS Direct connect Network errors
Hello All, I've had a Ready NAS Duo V1 for some years now, no problems at all. Always connected to the router. Anyway... Things have changed and I need to connect directly to my Mac (running Hi...
Mar 07, 2022Guru - Experienced User
Ianbpro3 wrote:
RX packets.... 4 errors?
Yes, over 100M received packets. Those aren't enough errors to explain a major slowdown. The bulk of the network errors were reported on the PC, and those are on the PC RX (so the NAS TX).
If jumbo frames aren't helping, then you should turn them off.
Have you looked for disk errors in system.log and kernel.log?
Ianbpro3
Mar 15, 2022Aspirant
Thankyou. I've had a look at the logs, and took a screenshot of the last ones, there looks like there could be something going on
- StephenBMar 15, 2022Guru - Experienced User
upnp isn't going to work with your ethernet connection setup.
I don't think those errors will cause a network slowdown. But you could turn off the upnp and bonjour services in Frontview (Services->Discovery Services) and see.
- SandsharkMar 16, 2022Sensei
What caused you to disconnect from the router? If it wasn't working any longer, and you've already tried a new cable, then I'm beginning to suspect a hardware problem in the NAS with a weak (but still marginally operational) Ethernet transceiver.
