Drug_Store
Jun 14, 2018Aspirant
Ready NAS NV+ (RND4425) - IP problems
Hi,
I have a strange issue with a RND4425, and don´t really know how to solve it.
Ok, so if I connect by a small gigabit unmanaged router GS608 v2, I keep getting 192.168.168.168, totally unr...
Jun 14, 2018Guru - Experienced User
The 192.168.168.168 address is the address your NAS uses when it can't get an address via DHCP.
Try a different cable next - 100 mbit ethernet only uses 4 of the 8 wires in the cable; so one possible explanation is that one of the other wires has failed.
- Drug_StoreJun 14, 2018Aspirant
I already tested with 2 diferent cables.
I guess I´ll try another.
Thank you
- StephenBJun 14, 2018Guru - Experienced User
Make sure they are at least cat 5e.
You can also try the cable with a different gigabit device connected to your switch, and see if you get an internet connection to that device.
During more tests, I excluded the cable part, as they are ok.
Connected my switch (GS728TP), forced the port to 100M full duplex, and started to ping the Nas...
So the problem is from the Nas unit itself. Don´t know what to do from here on.
