Drug_Store
Jun 14, 2018Aspirant
Ready NAS NV+ (RND4425) - IP problems
Hi,
I have a strange issue with a RND4425, and don´t really know how to solve it.
Ok, so if I connect by a small gigabit unmanaged router GS608 v2, I keep getting 192.168.168.168, totally unr...
Jun 14, 2018Guru - Experienced User
Make sure they are at least cat 5e.
You can also try the cable with a different gigabit device connected to your switch, and see if you get an internet connection to that device.
Drug_Store
During more tests, I excluded the cable part, as they are ok.
Connected my switch (GS728TP), forced the port to 100M full duplex, and started to ping the Nas...
So the problem is from the Nas unit itself. Don´t know what to do from here on.
- StephenBJun 14, 2018Guru - Experienced User
One possibility is that NIC socket or some of the internal components have failed.
This is an NV+ v1 (running 4.1.x firmware)?
- Drug_StoreJun 14, 2018Aspirant
Yes is rnd4225 nv+, so I think is v1.
Yes, running 4.1.16 (latest fw as far as I know of).
Disassembling it at this momment, and will see the NIC.
Thank you
Reworked all the solders of NIC (and 2 usb), but still same issue. Something is wrong maybe on the MB.
Anyway, it´s time to look for another data storage device... :(
Thank you
