LeStrangedream
Dec 06, 2013Aspirant
Ready Nas NV+ update issue
I can't seem to get my NAS to preform the update. I'm trying to go it from the local 4.1.13 file since it doesn't seem to find it in the remote update. It seems to just sit there on the update screen ...
Dec 06, 2013Guru - Experienced User
How old is the NAS? This could be a full OS partition (just one possibility).
You can try deleting all the logs (w/o downloading them). Though the best way to check is to enable ssh, and just look at the fullness of the OS partition with df.
